Welcome to FixYa.
Based on your description " makes squealing sound almost like beeping at the beginning of its cycle "...it is likely to be either the pump impeller or the inlet valve.
With the Bosch built line of dishwasher`s this is a known problem...the carbon ring ( spring ) of the impeller pump seal kit. ( make sure it is indeed a SHU9915UC before ordering parts )
**Most common in units not used regularly, i.e. in a holiday cottage or vacation property, but time to time on daily used as well unfortunately...but also due to the heat from normal wear & tear**
You first must determine which is the source of course. Does the noise begin after filling with water and the pump starts, or does it begin upon the filling of water ?
If it's the valve, make sure the water supply line is completely "open" and if so replace the valve with part #425458
i.e.
If it is the motor wash impeller squeeling It can be remedied by one of two methods, replacing the entire motor & pump assy part # 442548...
i.e.
My dishwasher(Bosch) makes sqeeling sound - e3a16c5.jpguploads/images/e3a16c5.jpg" alt="e3a16c5.jpg" class="h_mi" />
This retails between $99.00us. to as much as $170.00us. depending where you look. I usually go through "searspartsdirect.com" for about $100us. ( you can also investigate "repairclinic.com" or "appliancepartspros.com" to name a few.
Or if you are mechanically inclined, replacing the pump impeller kit. pMy dishwasher(Bosch) makes sqeeling sound - 08f460f.jpg5
i.e.
The kit is typically around $50 -$75us, hence it can be cheaper when factoring labour for the complete motor/pump assy.
This is a pretty involved repair to explain, in fact I think it is harder to explain than actually do...but I`ve done many.
If you`d like to provide me with an email address I can attach a file in "pdf" showing you step by step how you can do this without much cost at all really...likely your time will be the greatest expense.
Let me know how you`d like to proceed and I`ll help in whatever manner I can.
Thanks for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Testimonial: "we are still carefully listening to the sounds and its timing, we plan to change the impeller soon time permitting and will inform about the results"
Please send me pdf file mentioned [email protected]
Would you mind sending pdf to [email protected]?
thanks
would you please send the pdf to [email protected]
Mark - can you send me a copy of the replacement instructions as well? Thank you. [email protected].
Mark, would you please send the pdf to [email protected]? Thank you.
