20 Most Recent Bosch Evolution 800 SHE58C02UC 24 in. Built-in Dishwasher Questions & Answers
2answers
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
4/4/2022 4:16:42 AM • Bosch Evolution... • Answered on Apr 04, 2022
0answers
The dishwasher Quit working while in the wash
Make sure the connection of the plug is correct in the dish washer. ie: wire nuts did not come loose. you may a control board failure. this is located in the door of the dishwasher. hope this helps.
12/20/2010 4:41:54 PM • Bosch Evolution... • Answered on Dec 20, 2010
I would like to know
No, it's totally normal, The pump can't totally empty the washer and the hose because once it starts pumping air and water the air gives least resistance so the water remains in the hose. When the pump switches off gravity pulls a small amount of water back into the drain.
Your washer is 100% fine.
10/16/2010 9:32:00 PM • Bosch Evolution... • Answered on Oct 16, 2010
Dishwasher does not drain.
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Remove the control panel
Turn the breaker off. Remover the screws from around the door frame and from inside the door frame. Gently remove the control panel. Disconnect and remove the timer.
Installation is the reverse of removal.
Hope this helped you. Please rate if so.
3/22/2010 7:25:02 AM • Bosch Evolution... • Answered on Mar 22, 2010
How to reboot a Bosch Dishwasher please?
Question edited for clarity, add magic word. Question moved from Misc to maker category. Hold the Start button for at least 3 seconds.In order to stop a cycle that is currently programmed on your Bosch dishwasher, hold the Start button for 3 seconds until the light indicating that the dishwasher is active fades. On most models, the screen will flash "0:01" when you've successfully reset the machine.
How to Reset a Bosch Dishwasher: 7 Easy Steps - wikiHow
wikiHow https://www.wikihow.com > ... > Dishwashers ..
11/14/2024 4:28:24 AM • Bosch... • Answered 24 hours ago
4answers
All 4 lights on our Bosch Dishwasher are on and will not go out on front panel. Machine will not function
this is not computer, for faster help (100x?) post to dishwashers, never to computers, ok?
9/14/2024 6:01:59 AM • Bosch... • Answered on Sep 14, 2024
Bosch dishwasher constantly draining and it's not the fill switch.
I would check the signals going to the control board and that will tell me where the fault lies. It could be a simple triac/relay that has failed or something more sinister but unlikely to be the main board as you state everything else is working.
8/4/2024 7:32:01 AM • Bosch... • Answered on Aug 04, 2024
Does anyone know of a website that has pdf assembly drawings of washing machines?
This should help identify the item in question and the description will suggest its position. https://www.espares.co.uk/search/ma856pt1539/dishwashers/seals/bosch
7/9/2024 7:55:17 PM • Bosch... • Answered on Jul 09, 2024
Bosch SHU3322uc, washes and drains but inside still wet when complete
Hi Tracy, Usually the dishwasher remains wet after a cycle, so that's normal as long as it's a cup or less. However, excessive standing water that fills the bottom of your dishwasher means clogged filter, blocked drain hose or blocked drain pump. You can take the filter out and rinse under running water, also you can inspect the hose for any kinks that may be preventing water from draining. Hope this helps. However, if the drain pumup is cloged, you may need a professional technician to repair it. Regards, Dan
5/31/2024 4:27:53 PM • Bosch... • Answered on May 31, 2024
I have a Bosch SHE58C. What is making this noise?
This is the parts schematic that shows all the parts and where they are located. The noise is either something stuck in the pump or a dry bearing. https://www.searspartsdirect.com/model/25b4iqte9a-001794/bosch-she58c02uc-50-dishwasher-parts ..
5/14/2024 4:09:31 AM • Bosch... • Answered on May 14, 2024
2answers
Bosch dishwasher start with CL code
That is just saying the Child Lock (CL) has been activated.
Deactivate the child lock ' Bosch
Bosch Home https://www.bosch-home.com > ... > Get support 1. Press and hold the start button for three to five seconds ... When the child lock is activated, there will be a message "CL" in the display and all the washing ...
Bosch dishwasher child lock problem
Bosch-home.co.uk https://www.bosch-home.co.uk > ... > Dishwashers Hold down the lock button for three to five seconds. You should hear an audible beep and/or see the symbol disappear. The child lock is now deactivated.
What does CL mean on a dishwasher? And how do I fix it?
Quora https://www.quora.com > What-does-CL-mean-on-a-dish... This code means that the CHILD LOCK or CONTROL LOCK feature has been activated. When activated, all buttons will not change except the washer's door and the ... 9 answers · Top answer: First, look on your dishwasher to find a label that shows the manufacturer and the model number. ...
How to turn off the CL on the display of a bosch dishwashe...
JustAnswer https://www.justanswer.com > Appliance Repair Oct 28, 2010 - You should just be able to just turn the power button off, then turn it back on and the CL should be gone. 1 answer · Top answer: Hello, and thank you for using this service. I'll be helping you with your ..https://www.youtube.com/watch?v=Xr4DBwACUW4
4/15/2024 10:37:04 PM • Bosch... • Answered on Apr 15, 2024
Water dripping out of last hole in Bosch upper spray arm getting dishes below wet
the unit could be un-level
3/22/2024 4:43:03 PM • Bosch... • Answered on Mar 22, 2024
Model shy56ao5uc/23. How can I turn off alarm?
YOU CAN ONLY LEARN TO ATTEND TO IT WHEN IT SOUNDS . THEY HAVE NO FEATURE TO TURN IT OFF OTHERWISE
3/4/2024 11:14:58 AM • Bosch... • Answered on Mar 04, 2024
2answers
Bosch dishwasher error code c1
HiPump-out not accomplished in normal time.Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
1/20/2024 2:53:57 AM • Bosch... • Answered on Jan 20, 2024
3answers
Will a new Bosch dishwasher fit into the space of my 20-yr-old Bosch dishwasher?
Dishwashers come in standard sizes. Your old one is 60 CM wide and made for built in. https://www.bosch-home.ca/en/supportdetail/product/SGU4025AU/31 DISHWASHER 60 CM BUILT-IN/BUILT-UNDERSGU4025AU/31 As long as the new one is also for built in, the dishwasher will fit. Measure the height of the space you have. There may be a little height adjustment on the feet. ..
1/3/2024 11:11:40 AM • Bosch... • Answered on Jan 03, 2024
Bosch dishwasher leaking on the back
AI Bot Answer Deleted. In the base of the dishwasher above the floor there is a plastic tray that has a leak sensor. If you see water behind the machine than it means you have a 'spraying leak' as the sensor cuts off the machine as soon as it is triggered. It is likely to be a leaking hose on the pump. It can also be caused by the machine over-filling. An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher? Please turn off the water inflow and contact Bosch Customer Support for assistance.
E15 Bosch Dishwasher Error Code
8/27/2023 3:43:43 PM • Bosch... • Answered on Aug 27, 2023
Bosch Evolution 800 SHE58C02UC 24 in. Built-in Dishwasher Logo
10 questions posted
Top Bosch Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
dishwasher not drain
  • Dishwashers
