I keep getting a E22 warning,I have removed the filter and checked the water but cannot find a problem
E22 is residual water in sump, this could be blocked pump, dirty filter, grease build up. If you have removed white pump cover to check for blockages, ensure that it is completely clipped back into position before trying again. The non return valve maybe allowing dirty water to drain back into the machine. If you tend to run a quick wash a lot, you may need to boil a kettle and pour it into the sump to clear any build up from around the optical sensor in the sump. Post if you need further assistance
Posted on Feb 23, 2013
Apr 24, 2016 | Bosch Dishwashers
Jul 02, 2015 | Bosch Dishwashers
Good morning Diane Snow, thank you for your inquiry!
I see that your Frigidaire washer is displaying "E22" error code. Typically an "E22" error code means water is not pumping out fast enough. I would suggest checking the hoses for any restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would recommend having a professional come out and properly diagnosis your washer. I hope this information has been helpful. -Matt
Oct 06, 2014 | Frigidaire Washing Machines
Aug 05, 2014 | Electrolux Washing Machines
Jul 19, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Nov 25, 2010 | Haier XQG50-QF802 Front Load Washer
Nov 19, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
Oct 17, 2009 | 2004 Kia Sedona
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Apr 12, 2008 | Indesit Dishwashers
Jul 07, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
20,437 people viewed this question
