Sounds like you need a new ignition switch. It is usually located on the drivers side of the steering colum about 10 inches above the floor. Make sure the key is in the off position before you start to take the switch out.. the connector on the swithch come out just squeezing the clips on the clips on the ends of the connector and pull it out of the swithch. There are 2 screws that hold the switch in place, (Besure to notice the rod that fits into the back of the switch, this rod comes down from the key mechanism) When you put the new swithch on. line the bent rod up with the hole in the back of the switch. Replace the screws, and connector and your ready to try the new swithch out. This should start the truck the way it should, with no accessories while starting. Hope I have been of assistance in curing the problem.
the door lock motor assly could be bad.during self cleaning process the motor runs and locks the door and activates a switch .the control reads the swithch.if motor does not tunrn the door is not closed and it does not activate the switch.at the maximum it could be the control itself gone bad and able to read the switch.but that is less likely.
i am unable to get a signal on dab or fm ,whether on earfone or speaker .
