The hold button on my PSP is not working. I may have dropped it once or twice but the hold button was working fine after that. It was until now, that when i use my psp, the L and R buttons start changing the songs while i'm on the train or when i'm reaching in my pocket... even though my PSP is on hold. It's seriously a pain in the **** but i really hope it's not a physical malfunction (as to a digital malfunction)... i really hope not... i don't wanna spend money to get it repaired... it's hard enough to spend money on food. if anyone knows how to fix this, please say so!
Yeah, I do recommend you guys this site www.useegames.com I was quite satisfied with it, Although it came to my home 3 weeks later, but I really enjoyed it.Yeah, I do recommend you guys this site www.useegames.com I was quite satisfied with it,
You can't post conmments that contain an email address.
it's possible to unlock with a remote control.I Used a "One-For-All" remote.
This process is working on more that this Sony DVD players.
First prepare the remote control to use right device code.
1: Select the DVD button on the remote
2: Hold "Magic/Set" button util the LED blinks twice (Rabbit appears)
3: Press numbers 0533
Now program the remote control to send special codes on button 1 to 5.
1: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
2: Press numbers 994
3: Press "Magic/Set" button once
4: Press number 1891
5: Wait some time
6: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
7: Press numbers 994
8: Press "Magic/Set" button once
9: Press number 2552
10: Wait some time
11: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
12: Press numbers 994
13: Press "Magic/Set" button once
14: Press number 0953
15: Wait some time
16: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
17: Press numbers 994
18: Press "Magic/Set" button once
19: Press number 2214
20: Wait some time
21: Hold "Magic/Set" button until the LED blinks twice (Rabbit appears)
22: Press numbers 994
23: Press "Magic/Set" button once
24: Press number 0795
25: Wait some time
Now the remote is ready for use on the DAV-X1
1: Start the DVD without any DVD in it.
2: At the same time press and hold "Eject" and "Stop" in and then press "volume +" to get into the service menu
3: Now use your programmed remote
4: Press button 12345 with a small pause between each num.
5: Press button 12345 with a small pause between each num.
6: Wait some time
6: Press button 12345 with a small pause between each num.
7: Now use your orginal remote and turn the DVD off
Tested to play Region 2 and Region 1 DVDs without any problems after this. (The remote i used was a Cameleon 6)
To do a factory restore on the PSP just hold the power button up until the system fully powers off. Once the system is fully powered off hold all at once start + select + square + triangle, while holding these four buttons turn on the PSP, once the PSP is on let go of these buttons, it should take about a mintue or so for the PSP to load back up. You should see the settings you first saw when you first turned on your PSP.
To reformat the memory stick just go to settings > System Settings > Format Memory Stick,
be aware by doing this you will lose all the information stored on your memory stick, including music, pictures, games, etc.... Hope this helps, best of luck, don't forget to rate :)
hold the power button until it beeps once this is known as a soft reset. then do the setup and see if it works. If not hold the power button until it beeps twice this is the master reset. select restore system settings and try it again. If it still doesnt work your Hard drive may be damaged. If you replace your hard drive and still have the problem its your motherboard. a new HD will run you anywhere from 39.99 to 129.99 depending on the GB you want a new motherboard would run you anywhere from 20.00 to 40.00
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
one for all rc 7652 works for this as do many others. 1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 000533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 001891 (this sets key 1 – the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 002552 (this sets key 2 – the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 000953 (this sets key 3 – the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 002214 (this sets key 4 – the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 000795 (this sets key 5 – the DVD button flashes twice) Done - the remote is now programmed and ready to use
Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That’s it, the next time you turn on the player it will be region free for DVD playback
I personally dropped the 00 that are marked red and it worked for me but it depends on model of one for all remote.
The easiest way to reset the PSP is to do a hard-reset. This means holding the power switch in the up position for around ten seconds. This will then shut off the PSP. You may then need to flick the power button either once or twice for the device to come back on.
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
First Remove the UMD from PSP if any
1. Switch ON the PSP
2. Press and Hold the Left arrow button until the Sound of "click" Stops.
3. Press and Hold the Up arrow button until the Sound of "click" stops.
4. Press the Down arrow button 4 times (so u will be in System Settings)
5. Press the Enter Button i.e X
6. Press the down arrow button 9 times so u will in "Restore Default Settings"
7. Press Enter button i.e X once
8. Press the Left arrow button once and then press X button once
9. Press the Left arrow button once and the press X button again
10. Press the X button
See whether u r PSP restart and solves the problem
Try doing a hard reset by holding the power switch in the up position for around ten seconds.
button either once or twice for the device to come back on. after a hard-reset, I always
have to press the power on button twice to get the PSP to fire up.
