Try reducing your sharpness value on either your TV or the player if applicable. Also disable any edge enhancement or "DVE" modes on the TV if applicable.
The easiest way to adjust sharpness control by the naked eye is with a calibration disc. Alternatively however, just for sharpness if you have a screen full of text and/or lines do the following;
Reduce your color/saturation value all the way down...this will make the picture black and white.
Then reduce your sharpness control until the "ghosting" effect or any additional white lines on text edges and line edges disappear.
Then you can return your color/saturation value back to normal.
Hope this helps!
we are running 8 video inputs into a multiviewer (2 hd-sdi bncs, and 6 composite bncs), and the other 7 signals are fine, so it's definitely not the monitor, but i will check with the actually dvd recorder settings. thank you for your input =)
