SOURCE: Replacement of front plastic screen
well, unless you are really really lucky and could find the same model at the local tip, you will need to ot\rder and replace the part through a repair center or parts center of sorts, quite costly
SOURCE: getting to th convergence board jvc av-48wp74
why do you need to get to the convergance board
SOURCE: What's the difference between AV-48WP30 and AV-WP74
They are both the same size screen. (48" diagonally)
width: 106.3cm
height: 59.8cm
C-Dog
if plays DVDs via rear connections what have you got hooked to it for regular tv reception? Hooked to the coax fitting, using antenna or cable or sat with a box or not?
Good news is if it works with DVD set is likely ok and you have some other issue----just need some more information to decide what that issue is.
