Kenmore HE2 Plus Front Load Washer Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer is showing a error code of f-28. What does this mean
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Jan 10, 2011
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629115
Points
28464
The F28 error code in most Kenmore models is a MCU (Motor Control Unit) failure or a wiring issue. You did not include a model number for your washer. Without a complete model number I am unable to supply you with anything other than generic help.
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
What does f-28 mean in a whirlpool washer
serial communication error / the communications between the central control unit (CCU) and the motor unit cannot be sent correctly go to www.servicematters.com look for L-78 PDF print it out but look for your own model just keep opening each one until you find it. and parts are pretty cheap on ebay and amizom. also believe or not but sears beat there price on some of the parts ive orderd hope this helps tammie
1helpful
Kenmore H2 PLUS reads F--28 code what does this mean?
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Here's the online repair manual for your
Whirlpool Duet Sport, but its identical to your HE2.
Give it time to download.
On page# 4-20 it shows how to access your MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
3helpful
2answers
What does trouble code f28 mean
f-28 was flashing on my washer for the longest time, first i had read that my heating element had gone out which was false, my washer still produced the steam and heat prior to error code f-28 then shutting down.The 2nd thing i read was F-28 meant the locking switch on the door was going bad which again was false, my washer would lock and unlock allowing me to feed more clothes. So i took it upon myself to remove the lower cover clean and was my RINSE filter which at that time I discovered the DRAIN tube was pushed against my wall not allowing enough water to flow out on my washers RINSE & SPIN cycle.
If you have this problem I would recommend following your service guide to trouble shoot the RINSE FILTER & DRAIN PIPE. The washer motor spins so fast that the washer itself need to drain the water out 10X's faster then a regular standard washer!
Hope this helps cause it did for me and saved my wife and I alot of money in repairs!
5helpful
F-28 code
F28 means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.
Reach up near the latching assembly & Attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
1helpful
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
How do i find what an error code means?
F11 Communication error CCU (control) and MCU (Motor Control)
. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
13helpful
4answers
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Alexander
vince
