sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
these units have a door hinge issue, 99% of the time the hinges will fix the issue. Check the hinge receptacles the part the hinges lock into they often will go bad at the same time.
Order the hinges and replace them it will fix the problem. The link below is where we get our parts from.
Hi there is no adjustment. to fix it you will need to change both hinges on the door. Some models have a roller which may need changing (on the oven frame where the hinges are located)if the door is creaking when opened or closed. wherever you go for parts you wil need the model and product no from the oven located around the door area.
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
TheseVideos will
help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at
our website
1how to remove your oven door for cleaning
or repairs and how to reseat the door when finished.
2How to change and fit oven door hinges.
you'll probably need to replace the whole door and hinges. the internal springs (inside the door) may have failed and allowed the door to drop and damage the hinges. don't believe it's fixable, but is replaceable. at what cost, i can't guess- even if the parts are still available! compare the cost of fixing to the cost of replacing! good luck!
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
