SOURCE: Can't reset my cordless Logitech mouse
you should hold the reset button on the receiver for 5 seconds. let it go and immediately press the reset button on the mouse once. If done in this order it should be ok.
SOURCE: Repair Help+Logitech Cordless TrackMan Wheel Mouse
This diagram helped me put my track man back together again. Thank you.
SOURCE: Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
SOURCE: logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
