20 Most Recent
Logitech Cordless Desktop MX3200 Keyboard & Laser Mouse Kit Keyboard, Mouse Questions & Answers
Release the scroll key
Open and power on the laptop.
Wait for the laptop to fully boot.
Locate the "Scroll" button at the top-left of the keyboard. It is under the volume panel and between the "F12" and "Pause" keys.
Press the "Scroll" button.
5
Test it by opening a spreadsheet and using the arrow keys to
move around on it. You can open your Microsoft Excel program or create a
spreadsheet online by using Google Docs (free online productivity
software). The "Scroll Lock" function will keep the current cell
selected while the screen moves.
6
Press "Scroll Lock" again to turn it off.
4/18/2012 2:45:24 AM •
Logitech...
Answered
on Apr 18, 2012
The keyboard doesn't type
Hello There!
Check if "Num Lock" is on.
Otherwise go on Control panel and click on Keyboard settings.
Reset the driver.
I wish I helped you & that this helped you at most!
Don't forget to rate & all the best! ;)
1/14/2011 2:30:18 PM •
Logitech...
Answered
on Jan 14, 2011
My Logitech keyboard worked perfectly
When my logtch does that is usally is a stuck key. It can also be a low battery or the antenna is too close or too far away.
Most of the time its a stuck key. turn it upside down and knock on it like you are knocking on a door. that usually will jar the keey loose. you may be able to find the stuck key by pushing on them and see which one doesn;t pop back or feel right. Don;t try to pry it loose do the knock.
If the battery has just enough power left you can get some wired things happening but usually it just stops working.
Move the antenna so that it is about a foot away and is clear line of sigt from the keyboard to the antenna. You may want to reset or reconnect using the button on the antenna and the bottom of the keyboard.
9 out of 10 times its a stuck key.
12/2/2010 8:12:51 AM •
Logitech...
Answered
on Dec 02, 2010
I have a dell pc ~ 15 months old that was bought
These devices will never auto connect after a battery change.
You must press the button on the receiver then the red button on the mouse. Then the button on the receiver again, then the red button on the keyboard.
The buttons on the devices (keyboard and mouse are on the bottom of the device.
3/21/2010 8:49:24 AM •
Logitech...
Answered
on Mar 21, 2010
Keyboard works but Mouse does not respond
Restore your computer through a Restore Point. Choose "Start"in the lower left hand of the screen and look for system tools after that just follow the step shown.
7/31/2009 6:10:28 AM •
Logitech...
Answered
on Jul 31, 2009
Ned simple set up instructions to connect logitech
receiver first one second and release then mouse, one second and release. then push button on receiver for one second again and release and push the red button on the bottom of the keyboard. if mouse does not connect call logitech receiver may be bad if the mouse connects but the keyboard does not try procedure one more time. if keyboard fails to connect again. call logitech. you have a 5 year warranty on all non gaming keyboards.
7/17/2009 4:33:03 PM •
Logitech...
Answered
on Jul 17, 2009
Keyboard is messing up...the keys won't type or
Sounds like its a problem with the receiver. Try reinstalling the usb receiver and make sure that its being recognized properly by windows. Also make sure your receiver is positioned good so its not to far from the mouse or keyboard.
If it is then type and if your having the same problems then they keyboard would be faulty at this point. Many times the main board inside of these keyboards go bad especially if water may have gotten spilled on them.
6/25/2009 3:51:52 PM •
Logitech...
Answered
on Jun 25, 2009
Logitech wireless combo mouse keyboard mk220
support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries.
• Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse.
• If the USB receiver is plugged into a USB hub, try plugging it directly into your computer.
• Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface.
• Restart the computer.
• If these suggestions don't work, download the Reconnection Utility from
http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM •
Logitech...
Answered
on Feb 28, 2024
How i can connect my logitech wireless mouse EN60950 to the laptop
Unfortunately, EN 60950 is not a Logitech model number. It indicates that the mouse (or other electronic product) was tested and met the European IEC 60950 standard. Here's a copy of a Logitech EN60950 certificate:
https://www.logitech.com/images/pdf/compliance/AGY-700-018651.001_AGY%20CERT%20CB%20HS%20A00086%20BAER%20CI%20(GGEC)_EUROPE.pdf .
Logitech sells several different wireless mice types. Some connect to Bluetooth only. Some connect with a specific USB wireless transmitter/receiver. The dongle is small enough to fit inside the mouse's battery compartment or stay in a USB port when the laptop is moved. (Older Logitech devices used the Unifying USB wi-fi adapter; new ones use the Bolt adapter.) A few models can be used with both Bluetooth and one of the wireless adapters. These can connect to two or more devices and then a single button switches between devices.
Please try to find the actual model of the mouse to get the correct information for connecting the mouse. Logitech support may be able to sell you the USB dongle if they have the correct one in stock.
I hope this helps.
12/8/2023 11:47:00 PM •
Logitech...
Answered
on Dec 08, 2023
