SOURCE: keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
SOURCE: Blades need replacing.
If there is a joann fabrics store nearby, they have them. I think you can also order them online:
www.joann.com
SOURCE: My top looper does not go all the way to the left
Hi, you have to set the timing for your top looper. Mechanical aptitude is required to set the timing since its a very sensitive and critical. I can probably help you look for me at www.sewingmachineryrepair.com
SOURCE: My serger will only sew a few inches, then the
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
SOURCE: I have a white speedylock
These cord/pedal sets are available at http://www.sewingstyle.com/White-Sewing-Foot-Control.html
make sure that shape of the connector looks like that of your machine.
