20 Most Recent White Sewing 1300DE Sewing Machine Questions & Answers
you can download another one from the manufacturer. Just go to their website.
White Sewing... • Answered on Apr 09, 2014
check with these sites a1sewingmachine.com sewvacdoctor.com
White Sewing... • Answered on Dec 03, 2013
it would be a good idea to have the machine serviced..
White Sewing... • Answered on Jun 20, 2013
here's some links for partshttp://www.drdanessmh.com/whitesergerparts.htmlif you don't find what you need , send me a comment & I'll tryto help you
White Sewing... • Answered on Aug 23, 2012
Go to singerco.com and download your manual for free. All you have to do is put you model 1300 in the box and you can download it, save a copy on your computer or on a memory stick so you can always have it.
White Sewing... • Answered on Dec 23, 2010
Hi! I love the old Singer sewing machines!! Do you have the user's manual for your machine? The manual has great diagrams showing where to put oil and grease. If you don't, check out http://www.221parts.com/
In the meantime, look for little holes, often with raised edges and put a drop of oil in each. Put a drop of oil wherever metal moves against metal. You'll need to oil inside the head, on the right-hand side where the motor is located (DON'T oil the motor--use grease instead), and also underneath.
Good luck and let me know how it goes.
White Sewing... • Answered on Jan 12, 2010
First of all what kind of machine is it. where is your manual.If it's a overlock its not that hard.
White Sewing... • Answered on Aug 06, 2009
Your tension should be between 3-5 but all your dials need to be right around the same setting. Try them on 3 then go to 5 see what the difference is and then adjust accordingly.
White Sewing... • Answered on Apr 21, 2009
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
White Sewing... • Answered on Feb 17, 2009
you need to lock the dial after rotating it to the new stitch pattern
White Sewing... • Answered on Apr 03, 2021
While turning the handwheel towards you monitor the needle when it begins to rise. Look where the needle and the hook (under the bobbin) are. The hook has to cross the needle at just the right time (timing). This is the most likely area that is wrong. If the timing isn't right then something caused this which means needing a repairman to fix.
White Sewing... • Answered on Mar 19, 2021
Different model but likely close enough.
https://youtu.be/9OO9NuHWSuA
White Sewing... • Answered on Feb 02, 2021
You can watch here thousand of Movies, Shows. Now you can easily Activate Amazon by visiting amazon.com/activate you can watch prime videos anywhere on your device. Users need to create an Amazon account if they don't have an Amazon account and enter the Amazon my tv activation code to watch Amazon prime videos on your device. https://www.amazncomamazn.com/
White Sewing... • Answered on Feb 01, 2021
White Sewing 1300DE Sewing Machine Logo
27 questions posted
Top White Sewing Sewing Machines Experts
tina gallow
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • White Sewing Sewing Machines
Most Popular Question
recommended tensions white 534
  • Sewing Machines
