20 Most Recent White Sewing 2037 Mechanical Sewing Machine Questions & Answers
www.fixya.com/support/t27227243-white_sewing_machine_model_2037_foot_dog
5 days ago - My material won't advance how to fix. ... The little white button on the lower right front of the machine is the button that drops ... If your machine doesn't feed fabric after doing what I've outlined then you ... check the feeddogs & see if there in the up position, if there not move the lever or knob to the up position SOLVED: Threading a bobbin for White sewing ...
1 answer
Jan 7, 2018
My Singer 9420 is not advancing the fabric. The ...
Sep 20, 2014
SOLVED: Baby lock serger will not feed, fabric ...
1 answer
Jun 14, 2012
SOLVED: Feed dogs won't raise up again
Mar 21, 2009
More results from www.fixya.com
White Sewing... | Answered on Feb 20, 2019
Okie Dokie..... Here's the way I see it.. The repair center was of little or no help to you . So, I will try to do my best..
First thing you need to do is unthread your machine and set the tension to 4.. Rethread the machine up to just before the needle.
When you get that far, put the presser foot down. If your thread pulls right thru easily, it is not threaded thru the tension wheel right. It your thread is hard to pull thru with the presser foot down, then it is threaded right.
General rule of thumb..
Loops on the bottom-- problem on the top
loops on the top--- problem on the bottom.
Hope this helps..
Mimi
White Sewing... | Answered on Nov 28, 2017
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
White Sewing... | Answered on Nov 25, 2017
Try searching for:
sewing machine timing
There are a lot of videos/web sites that offer instruction.
White Sewing... | Answered on Apr 21, 2017
remove the cover over the bobbin section so that you can see the needle bobbin carrier interaction
now turn the machine over by hand and watch the needle go down and start to come up
at this point the hook of the bobbin carrier should be very close to the needle just above the eye of the needle
It is at this point the the needle thread is picked up and run around the bobbin carrier to link up with the bobbin thread
if it is not there then take it in for an adjustment as the adjustment is done by loosening off the clamp on the vertical bar at the end of the machine that moves the needle up and down and positioning the needle in the position described
if the needle is hitting the bobbin and the timing is correct , replace the needle as it may be bent or not in properly
White Sewing... | Answered on Jun 24, 2016
Sounds like what is normally referred to as "bird nesting" or thread nesting which is essentially caused, in the majority of cases, by incorrect threading.
Advise your wife to always raise the presser foot when threading the machine. This releases the tension disk so the thread will seat properly. If the thread is not seated in the tension disk, the upper thread will loop and knot under the fabric causing "birds nests"--an ugly mess of thread!
Be sure to install new needles frequently. A bent, dull, or nicked needle will be the cause of many frustrations. Also, avoid old or bargain bin thread. And use the proper needle for the thread and fabric of the project.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwij4crWxcnMAhVN9GMKHbZdBGYQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
The correct tension has been achieved when the upper thread and bobbin thread meet in the middle of the fabric. The starting point is usually the midway point between high & low tension number, and then testing and tweaking. This does not mean, however, that the tension needed for corduroy fabric will work on silk. There is usually some tweaking involved with every project, ie needle size & type, thread weight & material, type of fabric (heavy, light, knit, woven, etc.)
White Sewing... | Answered on May 08, 2016
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
White Sewing... | Answered on Jan 28, 2016
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
White Sewing... | Answered on Oct 19, 2015
you might need a different needle
and the tension should also be adjusted
you might also need some type of interfacing
White Sewing... | Answered on Jun 03, 2015
try putting the bobbin in so it unwinds clockwise
White Sewing... | Answered on Jun 01, 2015
It may just have wound badly. If you have not already done so, replace it or clean it off and retry. If you have done this already please add the details and resubmit
White Sewing... | Answered on May 30, 2015
Hallo Rhonda
Pls chk your bobbin locking at fixing shaft grew or not. on bobbin a sliding locking plate locks at shaft. while keeping in case chk that is loked by pulling. if it dosent lock , change bobbin with spare one.
White Sewing... | Answered on Mar 28, 2015
Use white lithium grease on the gears, and sewing machine oil on the other ... or broken, get a replacement from your sewing machine supplier
White Sewing... | Answered on Mar 07, 2015
you might have to use some force but not enough to break
the bobbin winder spindle. it's also possible that there is something
wrong with the bobbin for it to get stuck on the bobbin winder spindle
like that.
White Sewing... | Answered on Oct 30, 2014
try this link for a free manual,, the information about oiling should be in it. if the info is not in the manual, contact singer and ask them if the machine is self oiling machine. http://www.singerco.com/uploads/download/1128_white-2037-x.pdf
White Sewing... | Answered on Jul 28, 2014
White Sewing 2037 Mechanical Sewing Machine Logo
109 questions posted
Top White Sewing Sewing Machines Experts
tsalagi152
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • White Sewing Sewing Machines
Most Popular Question
loose stitching underneath
  • Sewing Machines
