Your aquastop system is activated :deactivate by turning off the water supply, running the dishwasher so that it is expecting to fill (if you hold the grey square box at this point, you should feel it slightly vibrating, which is a good sign that it is working ok). Clear the filter in the aquastop. Turn off dishwasher via the reset as per model. Refit valve, turn on supply and check for water tightness. Finally, restart the the d/w and if there was a fauklt with the aquastop ( and not a different fill problem) this process should have reset it. Hope this helps.
Hi. I just got the message you sent me. I'm just reviewing your problem description and will get back to you very shortly. BElectric
When you start a program, can you hear a motor/pump running? If so, does this continue to run if you open the door without cancelling the wash program?
It would help me if you could describe the sequence of events after starting a wash cycle. Does this describe the problem: 1. Press start and pump starts. 2. Pump continues to run even with door open. 3. No water enters dishwasher and pump continues to run endlessly until the program is cancelled and/or you switch the power off.
When I start a program, I can hear a motor/pump running. It does continue to run when I open the door. How can I fix this?
