CLEAN WATER FILTER,CHECK HOSE,WATER SUPPLY ADEQUATE AND FILTER INLET HOSE ARE CLEAN.
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
