Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
