20 Most Recent Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le Questions & Answers
I have 7690-2 ROBOTOOLZ that wont run on batteries. Is there a fuse somewhere? Works with AC adapter but not handy on job sites
Page 18? https://www.manualslib.com/manual/1314734/Robotoolz-Rt-7690-2.html
ROBOTOOLZ RT-7690-2 USER MANUAL Pdf Download ...
https://www.manualslib.com > ... > RT-7690-2
View and Download RoboToolz RT-7690-2 user manual online. Self-leveling, remote-controlled, simultaneous level and plumb rotational laser system. Or contact the maker.
6/8/2021 10:13:05 PM • Robotoolz... • Answered on Jun 08, 2021
2answers
Dropped rt7210-1 bearings out laser and drive ok
Dropped my robolaser RT7210-1 and the bearings came out.
10/26/2017 9:02:24 PM • Robotoolz... • Answered on Oct 26, 2017
2answers
The laser will not light
First, be sure to clean the battery connection points with an electrical contact cleaner and be sure that the batteries are new, not just different. If that does not work, try placing the instrument in a freezer for at least 30 minutes. This worked with my 5 point Stanley Fat Max. The freezer will cause some condensation to form on the inside of the instrument, but why it makes the diode work is a mystery, at least to me.
1/7/2015 10:53:01 PM • Robotoolz... • Answered on Jan 07, 2015
Laser level problem
I had the same issue. The laser would only turn on intermittently and mostly not turn on at all. Since the green led would come on for 2 seconds when you first turn the rotary laser unit on (as per the user manual) I decided that the problem was probably with the remote. I took it apart (4 screws) and cleaned the corrosion off of the battery contacts on the slider switch and the two plates that the switch sliders make contact with. I also bent the two thin slider contacts so that they would contact the corresponding plates on the circuit board with a little more pressure. Put it back together and that seemed to fix it.
1/7/2015 10:51:58 PM • Robotoolz... • Answered on Jan 07, 2015
Were can I down load a robo laser rbo 1001 manual
nobody ever sent me any help. still cant operate
6/30/2014 12:46:50 PM • Robotoolz... • Answered on Jun 30, 2014
0answers
0answers
No light
Be the first to answer 1/4/2014 4:05:19 AM • Robotoolz... • Posted on Jan 04, 2014Be the first to answer
0answers
Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le Logo
37 questions posted
Top Robotoolz Measuring Tools & Sensors Experts
ADMIN Canada
ADMIN Canada
ray gallant
 Mikey
Mikey
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Robotoolz Measuring Tools & Sensors
Most Popular Question
dropped rt7210 1 bearings out laser
  • Measuring Tools & Sensors
