Ecoquest Living Air Classic Air Purifier Logo
Posted on Sep 22, 2010
The fan on my living air purifier doesnt turn anymore. Occasionally when I first turn the fan on, it will "try" to turn but stops almost immediately. do i need to replace the fan motor? Is it something I can do myself?
The fan stopped working on our Living air classic XL15 so we just changed the motor. The machine comes on but the fan doesn't. Is there a reset button that needs to be reset? Or something else to do?
Sometimes you have to give the fan a push with your finger. If that didn't work, check all connections, fuses, etc. Sometimes things get jarred. If you changed out the connections at the ends of the wires (they include new ones with the replacement motors) you may need to make sure that you connected and/or crimped them correctly.
My ionic breeze GP air purifier will not turn on. I turned it off to clean the blades and when I reinserted and tried to turn it on nothing happens.
Hi.
The filter will probably needs replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. New model use a completely different technology. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
The Living Air O3 purifyer has stopped producing the purified air. The contact panels (2) have been clean as well has the entire unit on the inside. Fan runs and the little orange light is on in the...
Wow, the purifying plates have been is use for over 8 years! I think that your problem, try a new set of plates. You can contact the company at 800 989 2299 to order some new ones. Or you can email me stevelam at ecobusiness dot com and I can help you get some plates. Hope this helps.
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
Regards.
Ginko.
Light will not turn on but the fan is working
Contact [email protected] and explain the problem. They will be glad to help you.
2answers
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Fan is not turning on
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Top Ecoquest Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
