This message happens sporadically; sometimes when the status beeps it only says what sensor is open; other times I get the time and "module 1 failure". I need to know if this is something I can fix. Also if a window or door is open and the alarm is not being set it beeps at odd times telling the door or window is open. I've been off work 17 mos and the company wants $80 trip charge and 15 minutes, then $25 for every 15 minutes after, plus parts.
Is the module or a sensor , wire near the panel ? Check for loose wire connections , wires on sensors and check the module for bad connections and let me know what you find , sometimes the module can act up too from a bad transformer or just a failing module
Dell BIOS Beep Codes: Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2
Processor Register Failure
1-1-3
NVRam
1-1-4
ROM Bios checksum failure
1-2-1
Programmable Interval Timer
1-2-2
DMA Initialization Failure
1-2-3
Direct Memory Access Page Register Read/Write Failure
1-3-1 - 2-4-4
Memory/RAM Not Properly Identified or Used
3-1-1
Slave DMA Registration Failure
3-1-2
Master DMA Registration Failure
3-1-3
Master Interrupt Mask Registration Failure
3-1-4
Slave Interrupt Mask Registration Failure
3-2-2
Interrupted Vector Loading Failure
3-2-4
Keyboard Controller (Input) Test Failure
3-3-1
NVRam Insufficient Power
3-3-2
Improperly configured NVRam
3-3-4
Video Memory(RAM) Test Failure
3-4-1
Screen Output Initialization Failure
3-4-2
Screen Retrace Failure
3-4-3
Failure Finding Video Read Only Memory
4-2-1
Lack of Time Tick
4-2-2
Shutdown Failure
4-2-3
Failure in Gate A20
4-2-4
Unexpected Interruption in Protect Mode
4-3-1
Memory Address Failure above 0FFFFH
4-3-4
Non Functioning Time Of Day Clock
4-4-1
Serial And/Or Parallel Port Test Failure
4-4-4
Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm
1-1-2
1-1-3
NVRam
1-1-4
1-2-1
1-2-2
1-2-3
1-3-1 - 2-4-4
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
3-3-1
3-3-2
3-3-4
3-4-1
3-4-2
3-4-3
4-2-1
Lack of Time Tick
4-2-2
Shutdown Failure
4-2-3
Failure in Gate A20
4-2-4
4-3-1
4-3-4
4-4-1
4-4-4
Cache Test Failure
If the problem is the Communication Failure, try to reprogram the Home Security System. The codes that you need are indicated in the user's manual. If reprogramming the Simon would not resolve the problem, try to get the master code from the manufacturer.
Reprogramming the device should resolves the issue.
Here are the beep codes for Dell. Count the beeps sequences and compare them to the list. Dell BIOS Beep Codes:
Beep Codes
Possible Causes
Corrective Action
1 - 2
1 - 2 - 2 - 3
1 - 3 - 1 - 1
DRAM refresh error
1 - 3 - 1 - 3
1 - 3 - 3 - 1
1 - 3 - 4 - 1
1 - 3 - 4 - 3
1 - 4 - 1 - 1
Two separate problems: Sensor failure and phone communication failure. Most likely, you've not been hooked up to a phone for a while but the system didn't know until it tried to transmit to the monitoring center that you removed a cover on a sensor.
I can tell you how to turn off the panel beeps, "beeps" not only includes the trouble beeps that are driving you crazy, but also the beeps letting you know it's counting down, either when you've just armed it or when you come home right before the alarm sounds.
Open the cover and enter your code using the red numbered buttons inside there. It doesn't beep when you press buttons, so press them well. When you've done it right, it will tell you to choose from the Start Menu. Choose "DELETE". Then, from the Main Menu, choose "OPTION #". Then press DONE. You have now turned off beeps. You haven't fixed anything and that sensor still isn't working but it's not beeping to get your attention now. Press SYSTEM STATUS two times to hear it tell you what's going on.
To turn beeps on again, open cover, enter code and choose ADD > OPTION # > DONE.
Beep codes and power LED status are pre-post errors. Usually beep codes indicate a problem with a memory module. Power LED is solid green for normal operation. Solid or blinking Amber color power LED indicates a power distribution problem. Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience. Thank You.
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit
will shut down until the power is restored. One 9-volt battery must be
installed to retain your personal greeting message and incoming
messages during the power failure. Occasionally outside factors, such
as power surges, may adversely affect the unit. If the unit is not
operating properly or if the light continues to flash once power is
restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Is the problem always on zone #1?
