Question about Dell XPS 200 PC Desktop
4 beeps on start up but no screen - Dell XPS 200 PC Desktop
Posted by Rob Backie on
  • Dell Master
  • 18,693 Answers
Four beeps is ram I believe. Take everything off and see if it starts and then put stuff back one at a time and see what is causing the problem
Posted on Oct 01, 2013
Rafael Ortiz
  • 259 Answers
Here is a list of the dell motherboard error tones.
  • Dell BIOS Beep Codes
  • Dell BIOS System Messages
  • Dell BIOS Post Codes
Dell BIOS Beep Codes:
Beep Codes
Possible Causes
Corrective Action
1 - 2
No video card detected
Reseat the video card
1 - 2 - 2 - 3
BIOS ROM checksum error
1 - 3 - 1 - 1
DRAM refresh error
Reseat the memory modules
1 - 3 - 1 - 3
8742 Keyboard Controller error
Reseat the keyboard connector
1 - 3 - 3 - 1
Memory defective or not present
1 - 3 - 4 - 1
RAM failure on line xxx
1 - 3 - 4 - 3
RAM failure on data bits xxx of low byte on memory bus
1 - 4 - 1 - 1
RAM failure on data bits xxx of high byte on memory bus
Hope this helps. :]
Posted on Oct 03, 2013
1helpful
Beeping sound when starting
Usually when you first turn the power on ... it's usual to hear a couple of beeping sounds . And then, you may hear whirling/clicking sounds when your disk starts up (rotating) and your CD/DVD drive starts up, etc.. Then the monitor/screen lights up and starts to show the operating system (e.g. Windows) panel ... as it starts up.
If your system just beeps ... and beeps ... and beeps... and nothing else happens, the screen doesn't light up and show anything (for a few minutes), it likely the system is not starting up properly.
If you can clarify what actually happens, maybe I can offer more suggestions/information to help.
It start beeping until XP window come up,
It could be a bad memory module. Try removing and reinstalling them. Try one module at a time to see if beeping stops . Check all other connections to make sure they are properly connected. Hope this helps.
Fix 3 beeps on a laptop and can not start up
Is this a rapid sequence or delayed sequence?....../ie
BEEP.BEEP.BEEP or BEEP........BEEP........BEEP
I have an IBM T20 and when I start it up, the screen does not come on, don't hear hard disk working, but the fan is working. There is beeping when started - 3 beeps, then follow by 3 beeps, and then 1...
That is likely. The beeps represent an error code. You might try borrowing an external monitor plugged into your laptop to see if anything shows on that screen when it boots up.
Beeping when you start it up
The memory stick may have gone bad. Try changing the memory. A faulty memory will cause the computer to beep while the booting starts.
4helpful
2answers
MY ACER INSPIRE LAPTOP MAKE BEEPING SOUND WHILE BOOTING.
when i power on my laptop the acer logo screen is displayed on screen then the computer start beeping and the laptop get struck.i replaced the ram but the same problem arise.I removed the ram but the laptop wont startup and no beeping sound.When beeping start the laptop cooling fan get stopped.
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
2helpful
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
2helpful
2answers
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
what you are hearing is a beep code, if its 3 short beeps then its the memory which has developed a fault and it may need to be replaced
Dell XPS 200 PC Desktop Logo
Mandeep  Singh
Mandeep Singh
Michael Thomas
Michael Thomas
