If the lid lock is activating then testing it electrically wont help. you say that the lid lock is working when you manually put the lid lock in the closed position., is that correct?if it is, does the machine work on the spin cycle once you have manually activated the lid lock? have you checked for damage to lid? please reply 4 more help.
sorry to keep asking questions but just trying to sort this problem for you. now does your machine have an lcd display?if it does select traditional wash, low water level, not auto water level. then push start. if it has not got an lcd display select low water fill, not auto fill, and push start. try to put machine on level ground before you do the cycles. by the way select cold water fill for the cycle and make sure the cold tap is on. please reply on how it went and we can rectify this problem quickly.
hi, sorry for the confusion, just needed to know which machine you have. it is an aqua smart machine , on your model it has no water level . now here is the instructions to get into fault finding mode. 1st-- turn power off then on at the wall. 2nd -- push and hold the WASH TEMPERATURE BUTTON and POWER BUTTON at the same time and hold for 2 sec"s then release both of them. 3rd -- push SPIN SPEED UP BUTTON 3 times. after you do this your SLOW AND HOLD LIGHT will light up indicating that you are in the fault finding mode. now on the row of lights from REGULAR to EASY IRON what ones are lit up? please reply to tell me what lights are lit and i will look in my fault code book and tell you what part is faulty.now to exit the fault finding mode ,turn power off on the power point. good luck
could be faulty. was the lid lock chattering ? is the lid seated properly? have you got an electrical test meter? if you have please reply and i can help you test it electrically. lid lock could have mechanical damage. by memory i think i have had the same problem on a customers machine and i changed the lid lock. the only other thing it could be is the control module.
The lid lock was clicking. I took it apart and watched the lock as i pressed the start button. pressing the start button would make the shaft of the locking armature go in and when i pressed pause it would move back out again only when i had it with lid catch in the closed position.I can get a testing meter from my dad, just let me no how to test it please. thanks.
Machine would not work in any cycle. I forgot to menton the machine went off balance cos it moved to the uneven surface of the floor. The lid is not damaged. Can the machine operate with just a small of water and no clothes?
hi. machine doesn't have LCD . it has a series of flush buttons with wash options( from regular to easy iron) underneath that row there are more buttons : temp(hot,warm,cold), spin(fast,med,slow,hold), softner(on,off), delay start(9hr,3hr,1hr), soak(on,off), advance(wash,rinse,spin). there is also a high efficiency button and a play/pause button. ther is also a spanner and lock symbol that illuminate. the whole panel is like a touch pad which the selected options light up in red. pressing the play button causes the lid lock to activate and the lock symbol illuminates. if u keep stuffing around with the buttons the spanner lights up.
