Brother P-touch QL-550 Thermal Label Printer Logo
A
Anonymous Posted on May 16, 2010
P-touch QL-550 Thermal Label Printer: Upgraded to Windows vista - updated drivers, but m...
Upgraded to Windows vista - updated drivers but my Brother QL-550 label printer does not print. What could be wrong?
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 14, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470467
Points
19564
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
I NEED TO PRINT A FOLDER LABEL FROM MY COMPUTER
I suggest you RTFM. You can download it from here:
http://www.ptouchdirect.com/ptouch/manual/QL500.pdf
There's also software drivers that you shoulda installed on your computer - the printer driver, P-touch Editor, addins for Word and Excel, etc.
QL-550 Label Stuck
Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
QL 550 won't print
It has no ink as it is a thermal printer.   Make sure you are using genuine Brother Thermal Labels.
I have a Brother QL-550 label writer and I need to do some printing in MS Word 2003. I have done this inthe past with a specific label size. I haven't changed anything in my settings and when I look at my...
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
2answers
Norman Weimar
Norman Weimar
k24674
