3E error means =overcurrent detected at the motor.
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (press chime and extra rinse keys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
