HP Officejet 8500 error: Fax log full ; Delete button from Log window also does not work seem to work.
Please press the set up menu on th eprinter which is like a tool(wrench)-----Arrow keys-----TOOLS-----OK-----Arrow Keys------Clear Fax Log------OK.
This will clear the fax log.
If still the issue persists, please follow the below steps.
1. Touch the Setup icon.
2. Scroll to and touch Tools.
3. Scroll to and touch Restore Factory Defaults. A Defaults Restored message displays.
4. Press the Cancel button to return to the main menu.
And then, again cleasr the fax log by following the below steps.
This will fix the issue.
The HP printers come with the HP
Solution Center software. The software allows you to adjust settings,
transfer images, send a fax and make copies right from the control
center instead of using the printer control panel. When you make a fax,
receive a fax or block faxes, a log is kept in the HP Solution Center.
You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy
Instructions
