20 Most Recent
HP DeskJet 6450 Printer Questions & Answers
WONT PRINT
to be honest with printers, they usually are the easiest to resolve, because it really is just drivers...
So what you want to try and do is uninstall the printer, if unknown follow these steps...
Go to Control Panel> Then to Add or remove programs/ Programs and features (depending on Operating system)
Look through list for HP printer and all associated...
best to uninstall all HP associated product, like the solution center and all, believe or not that part of the software can affect printing...
After uninstalling reboot the system and then, when it is back on, make sure the printer and all is disconnected..
then re run the installation CD.. but for better results, i recommend downloading the current drivers from the manufacturer website...
HP.comgo to support and drivers section and download the one that applies to your printer...
the reason i recommend this is depending on how long you had the printer, if there is any update of drivers, especially with a lot of fixes for the OS then you will get the latest from this download...
If after uninstalling and reinstalling fails then test the other USB ports if it fails then try to call HP...
Clips or cuts off half the page or just last line
hi, dont worry I will guide you throught the steps to fix this issue.
Please follow the instructions provided below
1. open Ms word
2. click on print
3.click on properties
4.click on pages, and chage the paper setting this would resolve your issue.
Printer using a black cartridge in one week. Loosing ink somewher
Unless you can find a leak or have stained paper, ink is not likely to be leaking out. Have you used non-OEM cartridges? Are you printing pictures? Did the refill say it was a PHOTO pak, etc? When you buy ink, look at the number of pages the new cart. will print before you purchase.
Have a problem with printer-
Unpluge the printer from the wall, take the ink cartridge out and roll the roller with your hand and look for small bits of paper. I am sure you will find a small one there.
Once done, put back the ink and restart the printer and let me know the status.
Thanks
Kevin
Scan option
The all in one solution software you used in XP doesn't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP 6450) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
