After formatting hard drive tried to install Windows XP again but could not do so due to Boot manager missing.Please let me know how do I Fix this problem.
The error befalls when your PC is unable to interact with Windows due to
the corrupted Windows installation, or it is trying to boot from a
wrongly configured or improperly connected hard drive or flash drive
among other external medium...... read more
I see you are having issue installing windows, getting an error the the Boot Manager is missing...
The windows Disc that you have is this a burnt copy? possible that the installation files on the Windows you have is incomplete.
But if I may ask before you tried installing this Windows what windows did you have on your computer?
Have you tried booting the disc directly from the CD drive instead of installing it from within windows.
Go into BIOS and change the boot configuration of you Computer make sure the the CD/DVD drive is selected as the primary boot option before the hard drive, once that is done restart your computer make sure that you Windows disc is in the cd/dvd drive, you should get a prompt on the upper left saying to boot from cd press any key - press Enter right away once you see that prompt this should boot from the disc for the installation to continue but if still it looks for the Boot Manager the copy of your installation disc maybe incomplete.
Also you can try to wipe clean you hard drive and try again again with the installation.
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
If the boot partition no longer can be found, then Vista will display the following error:
BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529
More Info MS KB 927391
Check points for fixing missing boot-manager:
Check that your boot device is configured properly
Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair".
Boot Manager is compressed
If by accident having compressed the entire boot partition, then Vista will display the following error:
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart
OR maybe try this first.
Check points for fixing compressed boot-manager:
If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
compact /U C:\bootmgr
compact /U C:\ntldr
If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
attrib -c c:\bootmgr
attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
The hard drive needs to be low level formatted, fdisk'd and FAT32 formatted prior to ME install. I don't know where to get free copies, but I've used both On Track's drive manager and Acronis v10. Bothe are very good your purposes. Both retail +- $50.00
How far do you get? Do you have a bootable windows xp disk?
