1999 Ford Explorer Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace rear hatch hinges - 1999 Ford Explorer
  • Anonymous Jul 02, 2012
    no they are not welded to frame i just replaced mine from junk yard one nut and one bolt
Anonymous
Level 2:
Scholar:
  • Expert 61 Answers
  • Posted on Mar 29, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
61
Questions
Helped
47478
Points
155
I don't think the hinges themselves are replaceable, you may find the hinge welded to the frame.. You can however replace the hinge pins. The pins are pressed in, and driven out with a hinge punch. Make sure you have a helper though, the hatch is very heavy.
  • Anonymous Mar 29, 2010
    Note: you also need to remove the bushings in the hinge, those are replaced at the same time.
    And don't forget to remove the c-clips before removing the pin.
1 Related Answer
Anonymous
  • 73 Answers
  • Posted on Mar 28, 2010
SOURCE: what is the nut size on the rear hinges (roof
those nuts are 5/16ths.
How do I replace rear door hinge on Honda Crv 2005? Also how do I prop up door?
Do you mean the gas strut (piston) that holds the hatch open? You can get a replacement at https://www.ebay.com/itm/174080374696. If you mean the hinges on which the door swings, that sounds like a welding job--- they're integral to the vehicle frame.
I have a 2000 Chevy Blazer and I can get the Rear Hatch to open but the tailgate won't come down?
Hi, check your lift supports or the hinges. If they're dented or bent, they might let the hatch open but not come back down.
Here's a link with a picture of the locations of the lift support and hinges. I hope this helps.
http://img.photobucket.com/albums/v453/leadnbrass/0050.jpg
3answers
My 2010 ford escape rear hatch window leaks all the time.
For a few years there were recalls on some rear hinges for the hatches. Run the Vin# to see if anything is listed.
Usually there are adjustments on hinge mounts and on the latch mechanism. New rubber moulding would help if the current moulding is torn or compressed.
If you have a sunroof, it may have a drain which is plugged or disconnected at some point and allows water to enter and dump rearward.
In a worst case scenario, the vehicle may have been hit and the opening is not straight enough to seal.
This problem sounds like a body shop or glass shop problem.
I would like to know how to replace the entire hatch on a 97 Jeep Grand Cherokee Laredo
when you lift the hatch open up by the roof there are two hinges with three bolts to each hinge thats where it comes off depending on if its power you will need to unplug the harness and that is ran under the head liner not much involved in changing a rear hatch good luck
How do you remove the rear hatch on a 2000 plymoth voyager
I supported the hatch and removed the hinges from the hatch.
Rear wiper inoperative. How to diagnose?
try slowly opening and closing the rear hatch-door with the wiper switch on and see if wiper trie to operate.I had an intermittent problem with no sound coming from any speakers,but I could see from the radio display that the station and song were being displayed,by chance Iopened the rear hatch and the sound came blaring out of all the speakers.Turns out there is an electrical cable that comes from the roof area into the center of the rear hatch(between the hinges) and from flexing as the hatch opens and closes several wires broke and would intermittently make up and sometimes go open again.Took vehicleto dealership and the fixed and or replaced that part of the wiring harness,claiming they had not seen that problem before,seems hard to believe,as no doubt all of these models had the same wiring harness.--Good luck
Have 2001 Ford Windstar. Had back hatch open and backing down drive way. Corner of hatch hit edge of the house. The hatch was pushed up & in aprox. 2" so it now hangs at a slight angle and won't close. ...
makes me wonder if it is just the hinge that is bent and maybe the body where it attaches to the van. At the same time I doubt some thing easy will do away with the $2k expense (sorry). Maybe an entire back hatch with hinges from salvage yard (make sure to get same color).
39helpful
2003 Honda Odyssey Brake light replacement
open the rear hatch. Between the tail light housing and the rear hatch opening there is a trim strip with two flush fitted flap doors. Insert a small straight blade screwdriver into the small slot on the tail light side of the flap. Pry gently inboard and the small flap will open (the hinge side of the flap is on the side of the rear hatch opening.) Now you can remove the screws that hold the tail lamp assembly in place. Finally, there is still a "spear point" clip that fits into a socket near the front outboard corner of the assembly. Gently pry with a tape wrapped screwdriver (avoids scratches) and force the assembly straight back. The clip should release and free the assembly so you can change the bulb(s).
2answers
Defroster
FRONT DEFROSTER IS VACCUM OPERATED, ON PASSENGER SIDE REMOVE PANLE TO THE CENTER CONSOLE, YOU'LL SEE A CANISTES SHAPED IN TENNIS BALS IN SECUENCE, START THERE TO CHECK FOR VACCUM PROBLEM.
REAR DEFROSTER/WIPER/WASHER ON HATCH.OPEN REAR HATCH ON DRIVER'S SIDE HINGE YOU'LL SEE A WIRING HARNES GOIN THROUGH USUALLY THAT HARNES BRAKES , LOOSING CONTACT TO ALL OF THE ELECTRICALS IN HATCH DOOR, EASY REPAIR. REMOVE HINGE GET SOMETHING TO HOLD HATC OPEN, LIKE LONG BROOM.PULL OUT HARNES AND REPAIR.GOOD LUCK
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
