NorStar T7208 Corded Phone Logo
Posted on Mar 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
T7208 Nortel Norstar phone system - how to retrieve a deleted voicemail?
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on Apr 08, 2010
Anonymous
Expert
Level 2:
Answers
192
Questions
Helped
239388
Points
557
Unfortunately when a message is deleted... it is deleted unless you have a back up
How do i retrieve voicemail messages from an outside phone on a Nortel Networks T7208?
Nortel will have a phone number that you can dial from any other phone to retrieve your messages.
I'm locked out of the voicemail feature and I can't find a way of activating a new password to pick up messages. It's a Nortel T7208 system. Has anyone any ideas?
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the phone you are using.
1helpful
Setting up the Voicemail on a Nortel T7208
your mailbox number is the last 4 digits of your phone number
NorSTar T7208 Requirements
The Nortel T7208 set is propriatary which requires an MICS, CICS, or a BCM system to make it work.
How do i retrieve calls on my nortel norstar telephone from my home phone?
To access your voice mail remotely, while a greeting is playing (either the mail greeting or your own mail box greeting) press ** followed by your mail box number, password followed by the # ( ex. **,221,1234,#).
3helpful
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
1helpful
Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
1helpful
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
45helpful
2answers
Message waiting indicator light is on but there are no messages
There is this thing on Norstar systems called Reply message... this turns on your voicemail light, but there is on messages when you go into the mailbox.
Try this: FEATURE # 6 5
There might be something on you set that will tell you who sent the message, and you can hit the # or press the OK button to cancel this message!
Good Luck.
Top NorStar Lands Phones Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
