Question about NorStar T7208 Corded Phone
Need to reset my voicemail password without original password
The password for the voicemail on my Nortel T7208 has been lost through previous users, I was wondering if anyone had a solution to reset this password so I have access to my voicemail.
Posted by chazelwood on
  • Anonymous Mar 12, 2014
    how to reset voicemail message and password for retrieval
  • Anonymous Mar 29, 2014
    i want chnage password
terry gormley
  • 52 Answers
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
Posted on Nov 24, 2009
  • 2 more comments
  • rdhanekula Jan 05, 2011
    I tried the feature 983 on my T7208 but get a message "Not allowed" please advise. we have 4-digit extensions
  • Adam Jun 19, 2013
    I received the same message, but was able to access the feature from a different phone. My problem was the password. It did not accept the 1020000.
  • Adam Jun 19, 2013
  • Adam Jun 19, 2013
    OK, that wasn't supposed to post twice... Anyways, we have four digit extensions, so should I add another '0' to the password? Not at the phone that will let me access the programming right now, so I can't just try it out.
How to program nortel T7208 to have feature > 981 with an "other" option
After entering the mailbox access F981, press "#", the display should change from Pswd: to Log:. Now, enter the alternate mailbox number followed by the password for that box and "#". The remainder of the prompts should be the same as accessing the 'native' mailbox.
Nov 14, 2012 | Nortel Business Series Terminal T7208 -...
I'm locked out of the voicemail feature and I can't find a way of activating a new password to pick up messages. It's a Nortel T7208 system. Has anyone any ideas?
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the phone you are using.
Feb 18, 2011 | Platinum Norstar T7208 Telephone
Setting up the Voicemail on a Nortel T7208
your mailbox number is the last 4 digits of your phone number
Apr 26, 2010 | Nortel Business Series Terminal T7208 -...
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Sep 30, 2009 | Nortel Business Series Terminal T7208 -...
We lost the voicemail password!
If you have an in-house administrator, they can log in and reset it. You might try 0000 and 1234 just in case, otherwise you will have to call whatever tech help you have and get them to reset it.
Sep 03, 2009 | Nortel Business Series Terminal T7208 -...
My nortel voicemail is locked
What password is no longer valid? The admin, the operator, the installer?
What are you pressing to log in?
Jul 07, 2009 | Nortel Business Series Terminal T7208 -...
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
Jan 21, 2009 | Nortel Business Series Terminal T7208 -...
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
NorStar T7208 Corded Phone Logo
3,921 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
