20 Most Recent NorStar T7316E Corded Phone Questions & Answers
2answers
Templates
Hi there, most of the time, the technicians leave these Programming Overlays in the box, or in a box next to the telephone system.
You can look up these overlays via Google, or look for the programming template. We cannot tell you which buttons are for what, because each button can be programmed as something different on every set.
But here is a non-picture of the template... Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the 3 arrows that correspond.
Or you can look at this link below for a picture representation...
http://www.freevoicetelecom.com/docs/norstar_programming_basics.pdf
Good Luck!
11/14/2021 2:21:52 PM • NorStar T7316E... • Answered on Nov 14, 2021
Meridian phone ringer too loud
You can adjust the ringer of your Nortel phone by dialing Feature *6, then using the volume bar to adjust the ringer while the tone is playing, or dial Feature *80 to adjust it there.
6/1/2020 3:05:56 AM • NorStar T7316E... • Answered on Jun 01, 2020
Pickup Group?
The extensions must be added to a ring group and the the number programmed to ring that group
4/5/2020 11:34:48 PM • NorStar T7316E... • Answered on Apr 05, 2020
I have nortel phone system, voicemail is not working at all and feature 981, 983, 985 all say inactive feature--how do I reactive the voicemail??
Dear Annabelle,Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards;Ahmed Safaa El-DeebTelecom & Network Engineer
3/21/2018 2:03:04 AM • NorStar T7316E... • Answered on Mar 21, 2018
0answers
I have a mailbox I am trying to set up on a
I would say you have all your mailboxes used up. See if you need all the mailboxes programmed up, maybe you can delete one from another user.
1/5/2018 2:25:12 AM • NorStar T7316E... • Answered on Jan 05, 2018
0answers
Voice mail locked
Contact your phone service provider or look on line for instructions from the phone manufacturer.
11/19/2017 11:14:28 AM • NorStar T7316E... • Answered on Nov 19, 2017
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
9/25/2017 11:55:52 PM • NorStar T7316E... • Answered on Sep 25, 2017
I have a Nortel System T7316E. The display says
On the set displaying the message enter feature #871.
1/12/2017 7:18:19 PM • NorStar T7316E... • Answered on Jan 12, 2017
3answers
I need to know how
You would have to call the phone company and have them block long distance calls.
11/22/2016 9:00:42 AM • NorStar T7316E... • Answered on Nov 22, 2016
2answers
How can we block unwanted numbers on incoming calls?
Get Comcast we have a star feature that allows you to block numbers
9/30/2016 8:31:18 AM • NorStar T7316E... • Answered on Sep 30, 2016
Reset Admin password NorStar T7316E Corded phone?
You NEED to get SYSTEM documents (Hard Copy or CD) for NORTEL NORSTAR CICS before TAMPERING ...URL posted below... Found on page 24: Default Password Code is "admin" on your phone dial... Done by pressing 23646 on your phone dial... Time feature is accessed by inputting **8463 = (**TIME) Hope this helps... (CAUTION: read & understand BEFORE programming) http://phone.manualsonline.com/manuals/mfg/nortel_networks/compact_ics_61_system_coordinator.html?p=24
2/4/2016 3:01:05 PM • NorStar T7316E... • Answered on Feb 04, 2016
2answers
We have nortel t 7316 i have been locked out of the voicemail admin. i have tried all paswords i can think of but i cannot gt in. i have tried features 983 and than its ask me for login i have tried 1
Press Feature 985 - press 9 even when not listed in options. At the password prompt enter 73738767793 and answer the reset password prompt with yes. This will reset the password to default.
12/8/2015 12:40:33 AM • NorStar T7316E... • Answered on Dec 08, 2015
Feature codes
Does the two-line display say "Line in use" when you try select the line, or is the indicator next to the line button lit (so to speak), or both? First, try Feature * 0 then press each line key to see if they really are assigned to lines 2 and 3... they could be other functions or multiple appearances of another line.
8/27/2015 1:52:05 PM • NorStar T7316E... • Answered on Aug 27, 2015
693 questions posted
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • NorStar Lands Phones
Most Popular Question
t7208 mailbox locked
  • Lands Phones
