In stalled a touch screen stero and the power buttons doesnt turn off and is there an button that will turn it off. It is draining the car battery
There is a power button on your deck, but you must get to the screen where the clock is, touch the button and it will shut off, if not then we need to trouble shoot the situation, which is easy, if you take out your deck. and if you can find the blue wire w/ the white stripe that is located on your deck this is your remote wire, this cut the deck on and off, when hooked up properly, first your gonna need to extend this wire, so it can reach the fuse panel, then you need to locate the fuse that says cigarette lighter, pull the fuse out, and stick the extended remote wire there, then reinsert the fuse. now the deck should be off, now if you put the key in and turn it to on, the deck will come on, and when you turn the car off, it will swtay off, this will work i bet my rep on it.
