20 Most Recent Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player Questions & Answers
Im trying to get my
the red white yellow wires plug into the rear of the unit (white and red RCA will go into video or aux input) the yellow wire will go into video in (the red and white RCA from Nintendo they can go into either video 1input or aux input) on back of in-dash unit
hope this helped
4/2/2015 2:46:38 AM • Pioneer AVIC-D2... • Answered on Apr 02, 2015
0answers
2answers
Avid d1
Nope. Send it in.
12/2/2013 6:42:07 PM • Pioneer AVIC-D2... • Answered on Dec 02, 2013
Update my car stereo with new update
http://parts.pioneerelectronics.com/avicfirmware/
10/23/2013 3:31:25 AM • Pioneer AVIC-D2... • Answered on Oct 23, 2013
I need to update my car stereo
You can order the disc from this web link:http://parts.pioneerelectronics.com/avicfirmware/
10/23/2013 3:31:00 AM • Pioneer AVIC-D2... • Answered on Oct 23, 2013
Can I connect two Sub-woofer
head units do not provide enough power to run subwoofers. instead, get yourself some new door speakers, and enjoy the difference. if not, you will need an amp to power the subs.
5/6/2011 5:06:03 AM • Pioneer AVIC-D2... • Answered on May 06, 2011
Screen is not responding, off
you probably need to replace the touch screen
9/23/2010 4:29:46 PM • Pioneer AVIC-D2... • Answered on Sep 23, 2010
I need wiring diagram from factory radio bougt car
1993 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/Black
Radio Ignition Switched 12V+ Wire: Blue
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Yellow
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
pls rate because noone has been rating hope this helps
8/19/2010 7:44:46 AM • Pioneer AVIC-D2... • Answered on Aug 19, 2010
How do I remove a Pioneer car stereo using the
you slide them down both one each side and the deck should just pull out
rate pls
8/17/2010 11:28:52 PM • Pioneer AVIC-D2... • Answered on Aug 17, 2010
What are the speakers wire colors on a pioneer car
fr left + white
fr left - white/black
fr right + grey
fr right - grey/black
rear left + green
rear left - green/black
rear right + purple
rear right - purple/black
hope this helps thumbs up pls
8/12/2010 8:38:52 AM • Pioneer AVIC-D2... • Answered on Aug 12, 2010
What wires need to be hooked up to the positive
Red = positive to battery
Black = negative/ground to body
solid colored wires - positive speaker
while lined wires = negative speaker
Yellow = starter switch
6/7/2010 6:25:41 PM • Pioneer AVIC-D2... • Answered on Jun 07, 2010
Re-wire stereo in rover 400
The following should be right, unless your car has different wiring colours, there are a few variants...
Yellow and Red = Switched +'ve feed from the ignition
White and Blue = Permanent +'ve feed
Black = Earth (-'ve)
Red and Black = is for the illumination when sidelights are switched on
If the above doesn't work join the following MG-Rover forum: www.mg-rover.org And add me as the referer: HotTubRepairer
Regards,
Ian.
http://hottub.synthasite.com
4/1/2010 11:05:38 PM • Pioneer AVIC-D2... • Answered on Apr 01, 2010
The power buttons doesnt turn off and is there a
there is a power button on your deck, but you must get to the screen where the clock is, touch the button and it will shut off, if not then we need to trouble shoot the situation, which is easy, if you take out your deck. and if you can find the blue wire w/ the white stripe that is located on your deck this is your remote wire, this cut the deck on and off, when hooked up properly, first your gonna need to extend this wire, so it can reach the fuse panel, then you need to locate the fuse that says cigarette lighter, pull the fuse out, and stick the extended remote wire there, then reinsert the fuse. now the deck should be off, now if you put the key in and turn it to on, the deck will come on, and when you turn the car off, it will swtay off, this will work i bet my rep on it.
2/20/2010 5:38:59 AM • Pioneer AVIC-D2... • Answered on Feb 20, 2010
2answers
Pioneer car stereo-how to hook up speaker wires
ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
2/4/2010 7:42:26 PM • Pioneer AVIC-D2... • Answered on Feb 04, 2010
Need help on how to test pioneer avic d2 on a car battery
with high output stereos you shouldn't hook them up without speakers hooked up my shortout the outputs
all you should need for power is
acc
bat+
ground
12/22/2009 12:44:55 AM • Pioneer AVIC-D2... • Answered on Dec 22, 2009
The volume button is stuck down on my car
any good auto audio shop can do this for you. Circle City, is one.
11/29/2009 5:36:59 AM • Pioneer AVIC-D2... • Answered on Nov 29, 2009
I have a pioneer 6800 dvd and I seem to be getting
If yoa are using an amplifier, pioneer is notorious for not having a strong enough ground on the sheild of the rca's. What I do is get a splitter (1 male 2 female - radio shack or somewhere) Cut one of the female ends of and strip back the first sheild. It will be braided, take that and ground it to the black ground wire of the radio and it should be fine.
7/19/2009 1:51:28 AM • Pioneer AVIC-D2... • Answered on Jul 19, 2009
Pioneer AVIC-D2 In-dash Car Audio Stereo CD player with navigation and 6.5" video screen - Free UPS ... Car Video Player Logo
51 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
  • Car Audio & Video
