SOURCE: How do i videos from youtube onto my mp4 GoGear
Dowload youtube videos using sites like
www.keepvid.com
just copy n paste the video url in this site and hit download...
u can download the videos in mp4 format itself...
Done...
enjoy
Hope this helped
SOURCE: What video format does gogear vibe use?
According to the user's manual at www.philips.com it uses a compressed WMV format. The software that came with the unit will convert most video formats for use with the unit.
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
SOURCE: what video format can I put on my gogear vibe 4 gb
just use the songbird program that comes with the device, update it from the net, then drag n drop .avi and .mp4 files (this is all i've tried so far..). it will convert my 700mb avi movie files and put them on the device.
