E602
0001 A mounting fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0002 A data read fault of the HDD is detected when the HDD is started up from
the BOOT ROM.
0003 A sector fault is detected on the HDD.
0004 A fault is detected in the read /write address for the HDD.
Main cause The wiring is faulty (short circuit, open circuit). The HDD is faulty. The
main controller PCB is faulty.
BUT FIRST: TURN OFF THE COPIER SIMOULTANIOUSLY PRESS 1 AND 9, HOLD IT, AND TURN ON THE COPIER. THIS WILL INITIALIZE THE HDD DEFRAG MODE.
TRY IT, IF NOT REPLACE HDD, AND UPGRADE SOFTWARE - NOTE: FOR UPGRADE YOU NEED THE SERVICE SUPPORT TOOL - CALL SERVICE FOR THATH
How to handle paper jams on bypass tray on Canon np 6230
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
