The Fuse is located on the tonercartridge. Sometimes it helps if you use the cartridge without the fuse.The Fuse is located on the tonercartridge. Sometimes it helps if you use the cartridge without the fuse.
You can't post conmments that contain an email address.
Check the TONER Cartridge and Reinstall it CRU Fuse ErrorMeans : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]” message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display. 2 Press the scroll button < or > until “Ignore Toner” appears on the bottom line and press Enter. 3 Press the Scroll button < or > to select “On” or “Off”. Select “On” to ignore the [Toner Empty] message. Select “Off” to stop printing incoming faxes when the message appears. This is the default setting. 4 Press Enter to save the selection. 5 To return to Standby mode, press Stop/Clear.
such a suck fix problem site
suckkkkkker website
