Samsung SCX 4521F All-In-One Laser Printer Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer is showing the following error < CRU FUSE ERROR > what's this and how to solve it. Where can i locate the fuse in the printer?
Steve
Level 2:
New Friend:
  • Expert 147 Answers
  • Posted on Jan 15, 2011
 Steve
Expert
Level 2:
New Friend:
Answers
147
Questions
Helped
34429
Points
454
CRU = customer replaceable unit
Fuse error, or Fuser error. if the latter, go to www.partsnow, and buy a new fuser.
1 Related Answer
Anonymous
  • Posted on Apr 14, 2010
SOURCE: Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
It shows code 246 canon ir 2016
I think this is a strange error code. Let me help youWhat is the last activity that you carried out on the machine ? Did you try reseting the machine in service mode? If not do the following Press Additional function,2,8,Additional function Use < or > keys to scroll & select CLEAR. Press OK Use < or > keys to scroll & select ALL. Press OK. Now switch off the machine & switch on. Did this solve your problem.
6helpful
4answers
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
7helpful
What does system error E000 mean for Canon ImageclassD861 copier?
Remove the back plate go to Main Board then go to JP1 remove the Black jumper, connect the power cord, will show message error data and press Green Button (the Big Green for actv the copy) after that the machine do a reset and will clear the error. Return the back plate and connect power again and will work back fine.
TO RESET THE COPIER (after getting an Error Code of E000):
(Canon ImageCLASS D861)
1) Press the Additional Functions button
a. It will blink green
2) Press the < # > button
a. You will see the following:
SERVICE MODE
# 1 SSSW
3) Press the < + > or < ►> button until you see the following:
SERVICE MODE
# 7 PRINTER
4) Press the < Set > button
# 7 PRINTER
# 1 SSSW
5) Press the < + > or < ►> button until you see the following:
# 7 PRINTER
# 4 PRINTER RESET
6) Pres the < Set > button
# 7 PRINTER
< YES NO >
7) Press the < – > or < ◄ > button to choose YES:
# 7 PRINTER
# 5 MLT CLEANING
8) Unplug the printer and wait for 15 seconds. Then plug it back in.
16helpful
3answers
3helpful
2answers
How to solve CRU Fuse error ?
Check the TONER Cartridge and Reinstall it
CRU Fuse Error
Means : The toner cartridge is not installed correctly
You can set the machine to ignore the “[Toner Empty]”
message and to continue printing incoming faxes.
Ignoring the Toner Empty Message
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button < or > until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button < or > to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
4helpful
CRU Fuse error
The CRU is a customer replaceable unit such as toner and drum. New ones have fuses that tell the machine that it's new. When they are installed for the first time, the fuse blows and resets the counter.
CRU Fuse Error
xeregtei bna aa nadad ogooch pls
1helpful
2answers
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
2helpful
2answers
CRU Fuse Error
you need to replace the toner cartridge and or the fuse on the toner cartridge
http://www.websitetoolbox.com/mb/copierquestions
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
