AEG 24 in. Favorit 60830 Free-standing Dishwasher Logo
Posted on Jan 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the most usual reason for leakge on the AEG 6050?
What is the most usual reason for leakge on the machine when the pump continue running on AEG 6050
Joe Lishman
Level 2:
  • Expert 192 Answers
  • Posted on Jan 17, 2010
Joe Lishman
Expert
Level 2:
Answers
192
Questions
Helped
99061
Points
451
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
1helpful
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
20helpful
3answers
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
LAVAMAT MOTOR DOES NOT RUN
If there is water getting into the machine, then the motor, motor control unit, pressure switch, timer control and wiring harness must be tested. If the machine is a top load the motor coupler may replace the MCU of variable speed motors, that must also be tested then.
If cycle is not operating at all, with no water getting through the inlet check lid switch, door latch, inlet hose , inlet valve, membrane switch, Timer board and MCU if present.
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
15helpful
3answers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
AEG LAV86741 washing machine
hi,
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
post comment for more help...
good luck.....
1helpful
2answers
Anti-flodd Aqua Control
exact same problem here, we had power cut and after power came on the pump was continuously running with error EF3 showing.
This has happened before - design error with AEG
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
