Question about AEG 24 in. Favorit 60830 Free-standing Dishwasher
AEG OKO FAVORIT 6050 trips earth leakge
AEG OKO FAVORIT 6050 dishwasher trips earth leakge
Posted by mark_sandy on
  • Anonymous Apr 01, 2014
    I require wiring diagram
Joe Lishman
  • 192 Answers
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
Electricity tripping within seconds of closing the door of my AEG Oko Favorit dishwasher. Eventually gets going after about 3 attempts.
there has to be a short in the wiring check and make sure that the wires are connected correctly "White to White, Black to Black and Green to Green the green is the ground"
May 22, 2014 | AEG Dishwashers
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
I have a aeg 43070 vi dishwasher It keeps tripping the circit breaker on the house fuse box . I have reset the leak cutout by dipping the dishwasher back and stopped the warning sound,but went for about a...
I assume you are refering to the earth leakage circuit breaker. This trips when a earth leak fault has occured. The normal cause for this could be
A) Water leaking via a pipe at the bottom comming in contact with one of the electric motors at the base of the washer.
B) A heating element has gone faulty with a electrical leak to earth.
You need to test this with a multimeter on the OHMS scale and rectify any short to earth that the meter would indicate.
Mar 21, 2010 | AEG 23 in. Favorit 44070Vi Built-in...
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
Jan 16, 2010 | AEG 24 in. Favorit 60830 Free-standing...
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG 24 in. Favorit 60830 Free-standing Dishwasher Logo
1,533 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Michael Thomas
Michael Thomas
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
