20 Most Recent
AEG Favorit 50500 Built-in Dishwasher Questions & Answers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
I seem to have the
Hi
The polystyrene float you are referring is the water inlet valve where water hose is connected to. You would need to check & replace the water inlet valve. Hope this helps... Please post back if you need more information.
Daniel
My dishwasher keeps on draining and not filling up
First make sure that the float valve is not stuck up with some thing under it, Its the little plastic cap at the left front bottom of dishwasher and should move freely by hand up and down and you should hear a slight click.
Leaking
could be due to goalpost seal in poor condition or door latch needs adjusting
My AEG F86070VI dishwasher wont switch on
Did you check the emergency shut off switch? Almost all under the counter dishwashers have a wall switch to interrupt the power. The problem is it can be shut of on accident.
