For the UPnP architecture to work in Windows XP, the Internet gateway
device must appear in Network Connections. To make sure that the device
appears in Network Connections, click Start, click Run, type ncpa.cpl, and then click OK. Look for the Internet Gateway device:
Collapse this imageExpand this image
Also, the router must appear in My Network Places. To make sure the router appears, click My Network Places in the Network Connections navigation pane, and then look for the router:
Note
The name that appears is the model name of the router. For information
about how to enable UPnP on a router, view the router product
documentation. If these devices do not appear, make sure that the
correct components and services are installed in Windows XP. To make
sure that the correct components and services are there so that you can
enable UPnP, follow these steps:
Collapse this image
Collahow do i enable UPnP on my router - 941206d.jpgageExpand this image
I WANT TO CONNECT TO XBOX LIVE BUT SAYS I NEED TO ENABLE UPNP ON ROUTER IT IS A ZyXEL PLEASE HELP
SOURCE: BEFSR81 admin problem when enabled uPNP
in the router has one rest pin just press it for 3 min then after try to logged in but remind u have to configer agin
defolt ip is 192.168.1.1
user: admin
pass:admin
try it
SOURCE: upnp help for ps3 netopia router
Playstation Guides ( PS3 ) to change from NAT3 to NAT2...
Guide1 or Guide2 or Guide3
SOURCE: How to Enable UPnP on the router
it should be in your routers settings
192.168.0.1 D'link
192.168.1.1 Linksys ect.
SOURCE: How do I enable UPnP on this router WRT160N
on WRT160N router UPnP is enabled by default.
You don't need to enable it.
If you want to check the settings of the router then you will need to open the set up page of the router. Router set up page is a page where you can check/change all the settings of the router.
Is there any computer connected to the router. Check the Ip address of the working computer and open the router set up page.
Once you open the router seyt up page, click on Administration Tab. On that page at the bottom you will see UPnP. It must enabled.
Click Here for more information about router and
networking
