Also worked for me. I had done it once before and couldn't remember how to do the reset. Must have played around with the menu for hours.Also worked for me. I had done it once before and couldn't remember how to do the reset. Must have played around with the menu for hours.
You can't post conmments that contain an email address.
Check your owners manual. your machine may be out of memory. To free up extra memory, you can turn off
fax storage (see Turning off Remote Fax Options on page 64), print fax messages
in memory (see Printing a fax from the memory on page 46) or cancel a delayed
fax or polling job (see Checking and canceling waiting jobs on page 38)
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
The toner cartridge is a completely different unit from the drum unit. The drum unit is replaced separately, and is good for about 25,000 pages. The toner cartridge contains the toner powder. The drum actually fuses the toner powder to the paper.
After you install the New Drum unit you need to reset the drum counter to be able to use the Oce FX3000 again. Open the front door cover (the one you open to replace the drum or toner ctg.) On the control pabel hit the clear/back key. The display should say something like reset drum? Hit 1 for yes, close the door and you should be up and running again.
If there is no paper, load a new stack of paper into the paper tray.
If there is paper in the paper tray, make sure it is straight. If the paper is curled, you should straighten it. Sometimes it is helpful to remove the paper, turn the stack over and put it back into the paper tray.
Reduce the amount of paper in the paper tray, and then try again.
Check that the MP tray mode is not chosen in the printer driver.
If the LCD shows Paper Jam message and you still have a problem
Or try
Pull the paper tray completely out of the machine.
Use both hands to slowly pull out the jammed paper.
Press the cover release lever to open the front cover
Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
Put the drum unit and toner cartridge assembly back in the machine.
Unclip the whole printer cartridge and you should see a little blue tab that slides back and for.. Slide the blue tab back and forth servral times then insert the cartridge back into printer
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Replace the drum
