HP Photosmart D7160 InkJet Printer Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP photosmart D7160, ink sys failuar error code:
HP photosmart D7160, ink sys failuar error code: Oxc5d1281 what is this and how to fix it.
Anonymous
Level 2:
  • Expert 292 Answers
  • Posted on Dec 28, 2009
Anonymous
Expert
Level 2:
Answers
292
Questions
Helped
86166
Points
699
Hi otissr
If you are lucky, the solution given by HP in the following link will help.
Hope you wouldn't require a service call.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01936219&cc=us&lc=en&dlc=en&product=1156652
Good luck
If my answer is helpful, please give a rating.
luciana44
Ink system failure, how do I reset the printer
The ink system failure is caused by air in the ink feed tubes. This happens if you allow the ink to fully run out of the cartridge and it **** air in or if you use poorly filled refill cartridges that have air bubbles. To clear the error you will need to perform a purge on the ink lines to clear the air out. We have a step by step guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ The process will take about 10 minutes to finish but then you should have a fully functional printer again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
I keep getting ink system failure on my d7160 printer
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then reinstall the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Oxc18a0101 error message ink system failure
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone. http://www.fixya.com/support/t451942-help THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error16x16_smiley-surprised.gifxc18a0101 on photosmart D7160. This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
Ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
2helpful
I have got an error code, it reads 0xc18a0201. How do I resolve it?
Follow the steps on this HP link to reset the printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=uk&lc=en&dlc=en&product=1153481
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
13helpful
3answers
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
2helpful
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
