Year. I can use headphones and hear sound from the computor but not with the ada885 system . When I push the diagnostic button on the sobwoofer all of the speakers can be heard. One time I restored my computor to an earlier date and the sound started to work for a few days. I think autoupdate caused me to loose it but that is a guess. It seems to be around the time windows vista service pac 2 was loaded. Any thoughts?
SOURCE: ADA885 Clicking
A few possibilities exist. I would first check all the connections, and wiggle all the connectors and plugs to see if any one of them is causing it including the power cable. Also try to play with the ON/OFF/Volume switch to see if that's intermittent. Second, for quick isolation of the problem I would connect them to another PC - did the clicking and flickering go away? If it did, then your PC's audio circuitry is causing it - possibilities: defective audio card, or Motherboard (MB) if it has integrated audio, bad connections on MB or audio card, if you're also using analog audio connections going from the back of your CD/DVD RW to the audio card/MB then remove those wires and see if that problem goes away - those wires are notorious for picking up all kinds of noise and feeding that noise to your audio controller. One other thing to try is to completely uninstall and reinstall the audio drivers or even try a different revision.
SOURCE: Model ADA885 Power went out. ACP
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
or you might have to clean
the dust from your computer dust causes static which causes your computer to
overheat and all sorts of problems
be sure to wear an anti
static earth strap before touching anything inside your computer try
cleaning your computer of dust using a fine air blower from a compressor making
VERY sure that there is no MOISTURE in the air line specifically around the CPU
central processing unit and your SOUND CARD dust causes static to build up in a
computer causing it to overheat any many other problems
hope this helps
