You need to install a convergence repair kit. The AV48WP74-AV65wp74 convergence repair kit from www.tvrepairworld.com has the parts and the CD with instructions.
SOURCE: double images on top third of sceen
Faulty alignment mechansim or colour wheel. Expense unknown.
SOURCE: Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
SOURCE: my picture has double image and red shadow top and bottom
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: RCA 52 HDTV working fine when suddenly a band of
There could be a convergence problem. Try these:
SOURCE: DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
