Televison & Video Logo
Posted on Dec 05, 2009
Got a remote called easy remote want to set it to work philips dtr 1500 digi box but no codes or setup instructions for it
A
Anonymous
There is no Harmony remote called "easy remote". What is the brand of this remote?
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
How to setup phillips universal remote to a panasonic tv
More items...
Philips remote codes list
2969,2966,2961. Try these codes. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Need to work my tv with the remote
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Set up code for one for all remote on dgtec set top box
0473,0489,0413,0436,0422. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
76helpful
2answers
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
20helpful
3answers
How can i unlock philips hotel tv 21ht3302/41? -to play dvds
use av1, av2 , for tuning tv- use following sequence of commands on remote hand set
319753 mute
2helpful
LOst manual to setup Sagem ITD59g digi box.
press menu installation, then tap in 1,2,3,4 on remote for access code then choose user setting to take you to tuning menu
Philips activation code for a remote control
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
