Why does the inside has condensation and the dishes remain wet after the drying cycle?
Make sure you aren't selecting the eco setting to conserve power. Running a dishwasher in that mode disables the heating element that dries the dishes at the end of a cycle. Here a few ideas you can try,... with an empty dishwasher.. start a cycle and make sure you do not use that ECO mode if it has that feature.. then stop the dishwasher when it near the end of the cycle and open the door ./.. check to see if the water has been drained and that the heater element is on and hot. If there is a high volume of water in the bottom of the dishwasher, make sure the darin filter screen is clean and not restricting water flow... If that is clean.. and you have a lot of water in the bottom pan, you could have a problem with the pump, a hose in line with the pump or your house drain system is restrictive.. Good luck... and Hope this helps you..
