Bottom two lights keep flashing and will not print. when it does print it is blank. please help the printer goes from side to side sometimes when i push the print button but comes out blank.
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
Cancel button Print cartridge status light Resume button and light Power button and light
- If the power light is flashing it means that your printer may be receiving data. - If the resume light is flashing you may be out of paper, or you may have a paper jam, you may be printing a two sided document by hand and the first side has finished printing. - If the print cartridge status light is flashing that means the top cover may be open, of there may be a problem with one of the cartridges. - If all of the lights are flashing the printer may need to be reset.
Reset the drum count by pressing "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode"
Exposure mode is far left key on panel. You need to do this fairly quickly so that the display goes blank.
Once display goes blank then key in 24 then press print, then key in 7 then press print. You should now be getting flashing 000
Turn machine off then on and light should be gone.
Short version: C,far left,C,far left,24,print,7,print
Print a demo sheet. 1.Verify that inkjet paper is loaded in the paper tray. 2.Press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes green. Does a blank print appear? If so: How did the paper exit your printer? Quickly and smoothly Slowly and in increments If quickly and smoothly, contact Kodak at 1-800-421-6699. To expedite the call, provide the agent with the one of the following reference IDs - PH02 for image quality problems or BP01 for problems with blank prints. If slowly and in increments, reference BP02
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
Remove the printer from your system....uninstall the printer software(do so if you have the installation cd with you...or have excess to the printer driver)
reboot your system
plug your printer to the system and load the driver
this will work fine with you...if it doesn't do post what happens ...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Dear, after changing the cartridge, printer print a test print. OKAY.
Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left".
When the light stop fluctuating. Keep out the paper from the scanner.
After this Printer will work properly
