Hello my question is about what I think is a mirror issue on my n75 Nikon camera. When I look through the viewfinder the picture appears fuzzy. I looked closely at the lens and it does not look like it...
First off, with no lens attached, it will always be fuzzy, there is nothing to focus the light. Second, if you're looking at the mirror, you should be able to tell if it's dirty - if it is, glass cleaner and a soft rag are all that are required.
I'd suspect however that neither are your issue. Either your focusing screen is out of place or damaged, or your camera's diopter correction (if it has it) has been moved, Look for a small dial right next to your viewfinder with a +/- on it, and with the lens attached, and focused, turn the dial until everything is in focus. If your camera has this dial, it'll be usually on the right side of the viewfinder window.
If it does not have it you'll need to seek a repair shop to check your focusing screen since the mirror is 99% not going to be the cause of your problem. If there are no shops locally, google KEH Camera. It'll run you $35 for an estimate, waived if you decide to have any needed repairs done.
