20 Most Recent
Olympus Camedia C-750 Ultra Zoom Digital Camera Questions & Answers
Power button
my latch was broken at plastic not the door but on the camera. i drilled a very small hole in the door and then into the camera. i used one of the spare very small screws that came on my ring door bell and screwed the screw into the new hole .worked great
My Olympus Camedia C-750 will
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
C 750 olympus is not
According to user manjual, Olympus C750 accepts XD cards up to 256mb only, But according to info made availble by Olympus it can take up to 512 mb cards.I have never tried my self using othre than 128 mb card, except once I tried to use 1 gb card and it reported error saying 'cannot format'.I bleieve Olympus hasn't made attempts to make availble a firmware upgrade as the camera doesnt have ne more etramemory to accept updates.
Olympus Camedia C-750 Ultra Zoom Digital Camera not recognizing usb
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I think a defective battery
Hello
You can try removing then replacing back the battery pack. But I doubt if that will work. If it didn't work, you will gonna have to have it serviced and replace the camera's mainboard. But it might cost as much as buying a new and better camera.
Out of focus on any zoom, poor quality unless
Try this...place the camera on a hard surface or a tripod....snap a few pics at various zoom levels. Are the pictures better? If so, the problem is you....you're moving the camera without realizing it but when you use the flash, it freezes the picture because of it's extremely fast speed.
No PC connectivity appears when
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
